2015 TED unit replacement andpart umber?
Has anyone had to replace the TED unit in their truck? My driver seat unit has stopped working and now that its getting cold I miss my butt heater! The dealer wanted $450 to replace it but I figure it cannot be that hard.Plus I am sure the part can be had much cheaper than the dealer!
I am having trouble fining the part on the net. Anyone have a part number? Does the seat need to come out for replacement?
Is this what you are needing?
Control Module for 2015 Ford F-350 Super Duty|BU5Z-14C724-A : AutoNation Ford White Bear Lake | Parts & Accessories
Also, Is your truck out of warranty? If in warranty, it should be a covered item for warranty replacement.
Try this blower motor
Blower Motor for 2015 Ford F-350 Super Duty|8A5Z-19N550-C : AutoNation Ford White Bear Lake | Parts & Accessories
It's a $120
It's a $120
found it off of a image search....
OEM NEW 2009-2015 Ford Heated Cooled Seat Cushion Blower Motor Climate Module | eBay
and the truck has 56k miles on it, out of warranty for this kind of stuff.
It's a $120
It's a $120
Thats it! and its cheaper than what I just found on flebay.
Thank you sir!
Isn't there a separate TED in the seat back and another in the base?
I'm surprised to see a failure on a 2015. Are you certain the TED failed and not an electrical connection / relay / switch?
The seat base will probably need to be unbolted and tipped forward. Not a big deal.
The seat backs can be unzipped, revealing at least the plumbing but maybe a second ted.
When I had it at the dealer for the TSB update flash I had them look at it, they said it as the TED unit but didn't specify which one if it has more than one. They also wanted $450.00 so I figured I could save a few bucks by doing it myself.
Good question, I was under the impression it only has one. It will work for about 30sec- to a minute when its first started. You can hear the relay click when you turn it on and then hear it click as it shuts off all while the display screen still shows it to be on.
At $120.00 its not too terrible to give a try, I may dig a little bit more and see if i can diagnose it myself a little more. Maybe see what wire energizes when its turned on to see if the unit just does not work but it receives a signal.
