1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Optima battery finally going bad?
Old 11-20-2016, 07:02 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
First cold streak hit and I went to bring my daughter home tonight, go outside and truck fires right up and stop after ten minutes to fill up. go to start the truck and you hear IT that gut wrenching clicking!!!! tried a second time and same thing clicking gas attendant asked if I needed a jump and I said yes, while waiting I tried again and the truck fired right up like normal so now I'm like what?? I drop my daughter off at her mom's and go home, I shut it off and try again and it starts right up, I go in the house and waited twenty minutes and I just went out and it fired right up like normal SO WHAT'S GOING ON? I bought the battery in 2005 and had it in four of my mud trucks over the years then I cleaned it up and put it in my super duty a couple years ago, never had a single issue till tonight
Old 11-20-2016, 07:09 PM
ligito's Avatar
ligito
ligito is offline
Let the moths fly out of your wallet and buy a new one.
Don't let the kids get cold.
SuperDutyScaler
Been ten minutes since the first 20minutes after I got home and waited to see if it would start again. I have 12.38 at battery post with truck off I fired her up and it's at 14.2 at post, so should I let it go or could I have a different issue
Old 11-20-2016, 07:12 PM
SuperDutyScaler
Lol I have plenty of other bills opening the wallet just like everyone here
Old 11-20-2016, 08:14 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
My money is on a dead spot on the starter..
Old 11-20-2016, 09:00 PM
SuperDutyScaler
That would make is sound like the battery is dead with the typical clicking?
Old 11-20-2016, 10:47 PM
02F250V10's Avatar
02F250V10
02F250V10 is offline
Could be the battery, starter solenoid, or the starter. Your battery is going on 12 years old, it paid for itself long ago. Thats where I'd start
Old 11-21-2016, 07:13 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
Load test that battery before you just start throwing darts at a dart board. Could be something else entirely. 12 years is still normal life span for an Optima. Maybe a starter solenoid, starter, or even cables/connections between.
Old 11-21-2016, 07:41 AM
Irelands child's Avatar
Irelands child
Irelands child is offline
Clean/tighten the battery terminals, including the negative end on the engine. Then do a load test. I have an Optima that's 16 years old and is occasionally used to jumper start another vehicle, but is still strong. Then there is my current '11 truck with the original 2 batteries living on borrowed time if other folks replacements are my guide - I can hardly wait for that $225+ experience.
Old 11-21-2016, 07:43 AM
Tom's Avatar
Tom
Tom is online now
Sounds like you need to clean up your battery terminals to me. A dead battery isn't going to magically fire right up after a couple of tries.
Batteries can last a long time. Sold a '97 Lincoln a year ago that had a battery with a date stamp of 2003. Got me through the previous winter without issues.
Old 11-21-2016, 07:55 AM
RV_Tech's Avatar
RV_Tech
RV_Tech is offline
Agree with the preceding comments regarding testing to establish a course of action. May well be the battery, but there are other possibilities.
Old 11-21-2016, 08:49 AM
SuperDutyScaler
Old 11-21-2016, 08:57 AM
SuperDutyScaler
Parked the truck facing the wind last night after my original post, it's 38* with a steady 10-15mph wind which isn't cold compared to some places. Battery this morning was at 12.4 volts and after I started the truck which started completely normal is at 14.4 volts. All connections are clean and tight and covered with dielectric grease like I always have on them, I moved battery wires around and there is no cut or rubbed ones. Starter is tight and clean as well is the motor ground and chassis grounds. This is why I do all this inspecting and cleaning during the summer when it's nice out so I don't have any problems. I'm going to get the battery load tested but that doesn't seem to be the issue to me so I'll go from here and see what happens
Old 11-21-2016, 12:49 PM
99f350sd's Avatar
99f350sd
99f350sd is online now
Cables can have internal issues at the ends....Solenoid Going bad?
Old 11-21-2016, 12:56 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
also check belt tension on alternator.....often old belts will slip under charge load while the alternator resistance builds up during after start-recharge.
what the idle time....most alternators do not kick into charge mode until you hit X rpms which is usally above idel RPMs.
Quick Reply: Optima battery finally going bad?
