PCM won't comunicate with scanner 1995 7.3
Ok guys I have a 95 f-350 7.3. I am having an issue with a computer not being able to communicate with the pcm through my obd-I so we are thinking a ground issue I could only find one ground going to the frame and it is from the body (cab) the motor is grounded to the cab are there any other grounds that you guys know of that I should have or that I just can't find because those 2 grounds look fine
Yes it will. Well, it won't do STANDARD OBD-II, but neither will any other year OBS PSD. All our generation of trucks need something that understands "Ford Enhanced" OBD-II. The '95s just need to be flashed. Both our '95s talk to AE and AF just fine; they must have been flashed at a dealer sometime before we bought them. I've even got my ScanGauge-II to pick up a few parameters (although it won't obtain codes or do tests).
