If it's anything like the Sync system in the 2015 Ford Edge Titanium you should be able to turn it up/down with the steering wheel volume controls for the radio/phone.
Does this work for Google Maps through Android Auto also? Can barely hear the nav prompts even though all other types of prompts are plenty loud. Haven't been able to find any setting to adjust the Google Maps prompts though.
Your phone volume should be set to full volume. Check the volume on phone when using maps.
Ok, got a chance to go out and test the volume again. Set up a route, but with the phone in Android Auto mode it wouldn't give me volume control on the phone, even while it was giving voice navigation prompts.
Started up the route again and this time tried the steering wheel volume controls. This did work and I was able to increase the volume to usable level. The screen even shows that you're adjusting "Prompt volume". Can't believe I didn't think to try that before.
