Low HPOP Pressure no start need help
Old 11-19-2016, 06:10 PM
Anthony Polsinelli's Avatar
Anthony Polsinelli
Anthony Polsinelli is offline
I am unsure of what is wrong, story is i am helping someone fix their 97 e250 with the 7.3 powerstroke. I Plugged in my scanner and am not getting more than about 140psi in the hpop. He told me he replaced the ipr the icp and the cps. I tried unplugging the icp and still nothing. duty cycle is at 67.5 or something in that range (was 60 something i dont remember exactly) I am left thinking that it is the hpop itself or even the pcm. i pulled the valve covers looking for oil being pushed out from orings(he also replaced) or a stuck poppet and saw no oil coming out of anywhere.
a buzz test yielded code p1294 but all injectors buzzed. the UCH was all together and everything as well. I am at a loss, can someone please point me in the right direction?
I can get a 2001 HPOP, would that work on the 97? i know they have different angled something..
Old 11-19-2016, 10:00 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Is the 140psi cranking speed or idling because it takes 500psi just to start? Duty cycle should be about 12 at idle. A 2001 is a little better then the 97 but these hpop's hardly ever go bad.
Old 11-19-2016, 10:01 PM
Anthony Polsinelli
It's 140 cranking. It won't start. Also cranking somewhere between 100 and 150 rpms
Old 11-19-2016, 10:38 PM
fordpride's Avatar
fordpride
fordpride is offline
The pump is dead or you have a major HPO leak on the injector orings
Old 11-19-2016, 10:41 PM
Anthony Polsinelli
It doesn't appear to be the injectors. Wouldn't the same pressure be accomplished with the ipr stuck open?
Old 11-20-2016, 06:15 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
Shawn MacAnanny is offline
I can tell you mine with a new ipr and new icp will see 3400psi cranking over (usually when cold since a few glow plugs are dead) ipr duty is around 55 to 65%. Will it start with icp unplugged? I'd say hpop is bad or lpop
Old 11-20-2016, 06:24 AM
Anthony Polsinelli
No. It doesn't start no matter what. I think it was an aftermarket ipr
Old 11-21-2016, 04:18 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
Is there oil in the HPOP reservoir? I had a mysterious no start condition once and discovered that the HPOP level was somehow unexplainably low. Filled it and it's been fine ever since. Just a shot in the dark but it's always good to check the simple stuff.
Old 11-21-2016, 08:44 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
is crank case full?
Are you parked at an angle aka nose is up?
what is low pressure oil?
Old 11-22-2016, 07:48 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
did you get the hpop from the 2001
Old 11-22-2016, 09:51 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
There is quite a few places that low hpo can be caused by. It seems surprising that the hpop would just up and quit. But it has happened before. Places I would start are ensuring the hpop reservoir is full, icp and ipr pigtails are in good condition and properly connected, the tin nut is tightened onto the ipr, if that's all good I would investigation the wiring harness that goes under the fuel bowl. Also is he sure that the ipr orings didn't get damaged or rolled upon instalation?
edo488
15
08-21-2017 10:57 PM
elderivers
33
05-24-2016 05:19 PM
UGA33
05-22-2013 04:47 PM
steventothemax
05-13-2012 10:46 AM
autoboss
12-31-2003 06:15 PM
Quick Reply: Low HPOP Pressure no start need help
