holes in intake causing problem?
I have had a problem with my 2012 F150. It started spluttering and missing and barely able to pull itself. I used a code reader and found P0300 random multiple missfire, P2195 Oxygen sensor signal biased/stuck lean bank 1 sensor 1, P2197 Oxygen sensor signal biased /stuck lean bank 2 sensor 1.
I examined everything looking for a vacuum leak and found none. I did find a strange pair of open holes in the underneath side of the air intake structure. Two holes look like some kind of hoses should be attached. I stopped up the holes and it seems to have solved the missfire.
Can somebody tell me what the two holes are for? Has some kind of structure fallen off? I may have to go to a Ford dealership, but the nearest one is fifty miles away. Any help would certainly be appreciated. Thanks!
thegreatgate
1997 - 2003 F150
11-12-2014 06:02 PM
homeslicedave
02-22-2004 09:41 PM
