I recalibrated the PSOM for 31 10.50 15 tires using the code 9.14. Since doing that, the speedometer reads nearly 5 mph higher than it should at 70 mph. I'm wondering if I should reprogram it for a 30 9.50 15 tire using code 9.52 or try something in between those two. I have recalibrated the PSOM for this tire size before with the same setup on my last truck and the speedometer was accurate within 1-2 mph at 70.
I think the older PSOM's are only allowed 3 changes. Mine is a 92, and does NOT show how many calibration changes remaining, which I have read means it was limited to 3.
