2017 Horn Wire
I tied in behind the front grill. You will find 2 horns there and one with a plug. Easiest place to tie in. i was able to do everything without removing the from grill. Used a plastic pry bar to disconnect the horn wiring latch and fed the cable up through the top to have more room to work. Used a tap crimp and ran wire to my relay for trigger.
Initially i tried tracing the wire into the engine baby but everything merges together into a huge loom and i didnt feel like destroying that.
I plan to use one of the uplifter switches to engage air horn when regular horn is activated. From the wiring schematic, it appears I can cut the wire from the particular uplift switch fuse power and connect the signal wire from horn and negate the need for another relay.
snaponprofile
07-24-2011 01:44 AM
4020loaderman
09-25-2004 09:09 AM
