1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2002 F-250 leveling kit
Old 11-16-2016, 01:19 PM
Hoyt Tidwell's Avatar
Hoyt Tidwell
Hoyt Tidwell is offline
I have a 2002 Ford F-250 2wd and am looking for a good leveling kit. There's a 4" difference between the front and the rear and want to get it as level as possible. I haven't been able to find a leveling kit over 2.5" and I'm wondering if any of you have found one or have tried different methods of getting your trucks leveled
Old 11-17-2016, 09:59 AM
Norma stitz's Avatar
Norma stitz
Norma stitz is offline
I just put the zone 2.5" leveling mini pack on and it does a great job. I even took out the bottom smallest spring on each pack which made it more like 2". Ride is great and looks awesome. I think most of the 4" lift kits are a 4" front lift with a 1" block lift in the rear, so you could just toss the rear blocks if you truly want more lift in front.
Old 11-17-2016, 10:08 AM
ultrasks700's Avatar
ultrasks700
ultrasks700 is offline
I second the zone 2.5, made my truck ride so much better. Install was very smooth with the adjustable trac bar.
Old 11-20-2016, 10:31 AM
JNG6's Avatar
JNG6
JNG6 is offline
I was wondering how you handled the high torque requirements for the suspension components, especially the track bar? It appears that most people just use a cheater bar, crank on it and call it good. Thanks!
Old 11-20-2016, 11:03 PM
02F250V10's Avatar
02F250V10
02F250V10 is offline
I also have a 2" mini spring pack and love it but the OP said he has a 2wd truck. The front suspension is completely different. As for a leveling kit over 2.5 inches there is a reason nobody makes one. More than 2-2.5 inches you start messing up the geometry of the front suspension too much to get by without a full lift kit. If you want your 2wd level your options are a 2.5 inch level and reduce/remove the rear block or a full lift kit to get the 4" in the front you want.
Old 11-21-2016, 10:05 AM
89LX306's Avatar
89LX306
89LX306 is offline
The first time I did a suspension on a Super Duty I rented a torque multiplier. Easy as pie. The last couple of times I have used a big cheater bar and that worked well too.
Old 11-21-2016, 08:35 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
Your not going to find a level kit higher than 2.5 for your 2wd truck, there are 4" lift kits for the 2wd suoer duty and you might want to look into this and keep the rear stock instead of installing the lift components
Old 11-22-2016, 05:28 AM
ultrasks700
Crossfit...I produced that 400lb torque requirement with one hand
Old 02-10-2018, 12:03 PM
JNG6's Avatar
JNG6
JNG6 is offline
Strong like bull.....smart like dump truck.....It seems like most people install their own lift kits so I figured most people just crank on it and call it good. Cheater bar it is! Thanks!
Old 02-10-2018, 03:04 PM
Jo7.3's Avatar
Jo7.3
Jo7.3 is offline
1/2” drive impact works pretty good too, especially after fiddling with the suspension multiple times lol
Finz250
6.7L Power Stroke Diesel
24
08-26-2012 03:45 AM
parkland
6.4L Power Stroke Diesel
18
04-23-2011 09:28 PM
Bluebronco85
18
11-05-2008 05:46 PM
blong2107
04-16-2008 09:31 PM
ffadragon
13
02-16-2007 10:29 AM
Quick Reply: 2002 F-250 leveling kit
