Slow rolling over 7.5L, 1996 F-Superduty
I purchased this this truck last year and it has always rolled over slow. I replaced the battery, and the ground cable that runs to the block and inner fender. Are there anymore grounds? I didn't see one to the frame, where can i find it at? Does the starter ground through the block? I only found the two grounds coming off the negative post, one to the fender, one to the block.
I'd like to replace the positive cable also and have the starter tested at Advance Auto. Do you have a recommendation for cable thickness? If I remember correctly, there are two wires coming off the positive side, one goes to the solenoid, the other to the alternator?
Sorry, trying to remember this while I'm sitting in my tree stand.
Derik Landers
10-16-2017 06:30 PM
rong63
18
02-22-2006 12:42 PM
