1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2WD 99 F250 - 4 WD connector
Old 11-14-2016, 02:13 PM
ligito's Avatar
ligito
ligito is offline
Does the 4 WD connector that goes to a dummy plug on the back of the dash, have any power and can it be used for anything else?
Old 11-14-2016, 05:50 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
The connector behind the dash is likely inactive if you have a 2wd, since the PCM needs reprogramming to work.
You could install the switch and wire up your own wires to control anything you want.
It might be clever to have an anti-theft switch concealed as the 4x4 switch.
2wd => won't start
4x4 hi => won't start
4x4 lo => start enabled
Old 11-14-2016, 05:59 PM
ligito's Avatar
ligito
ligito is offline
outlawcustombikes
08-25-2012 06:26 AM
yamaguy
04-07-2007 10:44 AM
chopperkell
03-19-2007 12:53 PM
blhfla
05-15-2006 05:26 AM
Quick Reply: 2WD 99 F250 - 4 WD connector
