What are you running on there now.....235/75-16's? Is your question for the front or back or both, I don't think you would have a problem with the fronts at all. I ran 265-75-16's on my '02 without any rubbing. When I went to an 18" wheel i ran 285-75-18's with only a small rub at full lock.
Im running 235's now question was for all 4 corners although im more intrested in the rear. More specifically is there enough clearance between a pair of rear tires to allow 265's
