97 F-250 Glasspack Exhaust
11-10-2016, 07:20 PM
Just replaces the cat on my f250 as well as a cherry bomb muffler. I'm just unsure that the tailpipe exit is appropriate, it exits over the leaf spring with about 2.5" of clearence over the leaf spring. Is this okay
11-10-2016, 08:39 PM
Is it pointing straight at the tire? That would not be good.
11-10-2016, 08:45 PM
Quote:
Originally Posted by
raystankewitz
It is pointing at the tire. Could I just point it straight under the axel? If I could pass with a glasspack could I pass with that?
11-10-2016, 11:27 PM
it also looks like it's angled upwards ? not a good thing.
11-11-2016, 12:34 AM
Pointing up, directed at the tire and in between the frame and leaf spring. How did you come up with that routing?
11-11-2016, 07:34 AM
Yeah that's not good at all. Either route it over the axle and to the back, or have it come out before the tire pointing down.
11-11-2016, 07:52 AM
it is also laying against the shock boot.
A simple 45* coming out of the muffler aiming to the ground would be the easiest solution
11-11-2016, 01:47 PM
As Brad said, a turn down off the muffler is simplest. Good advice above.
Reason: Deleted rude comment
11-11-2016, 01:50 PM
No need to be rude to the guy. Some things that may seem obvious to some, may not be to others.
11-11-2016, 02:58 PM
Lead Head
You're right, that was out of line. I deleted the rude comment.
Ian Clarke
04-09-2019 11:48 AM
fifty-two_f1
06-19-2014 09:49 PM
OLD97F250HD
09-19-2010 03:51 PM
Pig Pen Jr
Exhaust Systems
02-19-2004 12:04 PM
