54 f600 on c3500 chassis
If I put the front clip on and line up the old lines where fenders meet cab the front of the hood is off by an inch or so. It's almost like it is out if square. I notched the tops and sides of frame rails so the support is in the center of rails. It fits nicely. Seems like it just isn't centered though
Hey guys.
What are u using for radiador?
And are you guus using electrical cooling fan or clutch type.?
I also had to notch The inside top part of the frame
My engine sits in stock location and its an inch above the crossmemer,track rod and the fan barely misses the front frame crossmember,brake lines and proportioning valve..
I want to move that crossmembetoat least 1" forward and move the brake lines behind that..
I dont want to go with electrical fan..
Who's truck is that in the pic? A member here? I like it a lot!
tinman52
13
08-12-2011 10:32 PM
powerstroke72
2010 - 2014 Ford SVT F150 Raptor
39
12-11-2009 01:54 PM
