NEED HELP ASAP!
NEED HELP ASAP!
I have a 05 f250 6.0L ( i know they suck) but I have a 12" lift with 40x20s. And I have a edge tuner. Check the codes earlier and here's what I found;
P0341 camshaft position sensor A circuit range/performance bank 1 or single sensor
P0606 ECM PCM processor
P0671 cylinder no. 1 glow plug circuit
P0675 cylinder 5 glow plug circuit
P0676 cylinder 6 glow plug circuit
Any my ideas on how to fix all of these?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
First off, welcome to the forum.......second of all the 6.0 doesn't suck, just takes a little extra effort at times to diagnose.
Does the truck run? If not you likely have a bad cam sensor, or a chaffed harness, or plug with corrosion perhaps. Take the plug out and inspect, put it back in, check the harness.
The glow plugs are simple, likely just needs new glow plugs in those holes.
The PCM might be related to the cam sensor.
im not gonna lie, reading your post chapped the ol backside pretty good....and as much as you just came across as whatever bad word you want to use, already guys here are stepping up to help.....much reps to navistarnut....and maybe your just frustrated and didnt mean it like that. but i love my 6.0 and wouldnt want any other motor.....give a little info, check the simple stuff, and go from there
Well, if you read much on the other forums that's just how people talk. Kinda what makes this site a little different. I'm not easily offended and this post don't bother me, but for this place, it is sorta gettin off on wrong foot. 12in lift and 40x20's isn't really my style, my truck has to work sometimes
