3.5L EB Oil Dilution
#106
It's been about 5,000 miles since I changed my oil, and much to my surprise the level is about 1/2" over the full mark. Haven't checked it in at least few weeks, and last I remember it was right at the full mark.
Up until now I was certain that fuel dilution had everything to do with driving conditions, but now I'm not sure. My truck almost never idles, and the majority of my use is highway miles. I drive about 1,500 miles per month, and other than a few short trips per week for coffee, my shortest drive is 6 miles at 70 MPH. I've ordered a Blackstone test kit, and I'll be sending off a sample for analysis when I get the chance to change it. Here's a shot of my engine hours screen I took this evening:
And yes do not idle a direct injected engine. And regardless of idle time, valves will eventually develop bad buildup. There's a Ford tech on you tube with a boroscope to show you.
I also have to wonder how big a roll, oil dilution plays in all the cam phasers we hear about going out. Good luck.
#107
Well, the 3.5 EB in Blue hasn't "made" any oil in the 2000 miles since it was changed, but basically all of those miles were towing something - either the trailer for Big Blue or the trailer and Big Blue. So the turbos were working much of the time, which might keep the rings seated better.
Having said that, the 460 in Big Blue seems to be "making" oil. I drained about 13 qts from a 6 qt system, with the top ~7 qts being gas, as described here. Do you think the rings are leaking?
#108
on
#109
Anyway, I couldn't help but comment on this thread. You are worried about 5% dilution and I had 116%.
Hijack over.
#110
All this talk about oil dilution got me to go out and check. My 2015 3.5L EB is now around 18,600 miles, and due for a change in about 1,000 miles. It's got 661 engine hours, and 77 of those were at idle (11.6%).
It has been sitting overnight, so all the oil should have drained down. The oil on the dipstick is "maybe" about 1/8" above the full mark. I consider that pretty close, and am going to declare it OK just because.
#111
Just got off the phone with Borg Warner. After 83k miles on the 3.5 and religious 5k oil changes. I'm about to order my third set of turbos. $2,300 for the performace upgraded version. The B.W. warranty dept. has informed me that the turbo manufacturing community refers to all ecoboosts as the turbo killers. You will "make oil no matter your driving habits" I.e. Oil level going up. The only hope to save the turbos is to change the oil more frequently, probably 2-3 k. Don't listen to this 5k hogwash, or you'll be lubricating your turbos with gas.
Should be able to go 5k or 7.5k with no worries.
biz
#112
#113
Pool Runner
2009 - 2014 F150
03-25-2014 07:39 AM
Lt CHEG
6.4L Power Stroke Diesel
02-08-2011 10:47 PM
