Vacuum advance
Vacuum advance
Im getting my truck ready to get smogged (79 F350 4x4) And the 460 in it is a 1987 year model , dont' know what it's out of just 87.
I have the initial timing set at 11 degrees btdc with the vacuum hose unhooked and pluged now when I plug the vac hose back on the distributor my timing jumps to 34 degrees, both taken at idle. The vacuum hose goes from the dist. to the bottom outlet on the heat switch on the thermostat housing with the top 2 outlets meeting at a Y and then to a manifold vacuum tree. The ported vacuum on the carb goes to another heat switch on the T housing then to the EGR valve. All these vacuum hoses look like they have been where they belong for a long time. Anyway I have 11 initial degrees advance without vacuum and 34 degrees with vacuum AT IDLE. this don't seem right ??????????
Gene
Gene
I'll try not to start a fire storm about manifold vs ported. But your truck is working as intended. It is not a street racer. That advance at idle was developed to increase fuel efficiency and reduce emissions, so I would not mess with it if your trying to smog in CA. Suggest you read this for more detailed understanding https://www.fordmuscle.com/archives/2000/03/timing/
jrlec1020
03-06-2012 08:34 PM
77trailerspecial
10-24-2010 08:31 PM
bigwalt1
20
06-18-2010 08:11 PM
81rangerF150
10-16-2004 09:36 PM
