Well, what we thought was just the water pump was actually also the timing cover gasket leaking, which means the cover is coming off... At that point, he'll be checking the timing chain.
PBY is correct. Go with a good true-roller chain & gears. I used an Edelbrock # 7830.Install it straight up. As far as the timing cover, mine leaked between the cover and the block.They become oxidized & pitted. Replace the cover. I used a Enginequest TC460N. If the dipstick tube is in the cover,replace it also.
