02 expedition 5.4 heat/heatercore flush
Im having a warm air issue front back
What is the easist way to fkush heatercore on theses? im use to pulling the two heaterhoses and doing it that way but i dont quite understand how to do it on these dual air expys im attaching photos.
could i just open rad petcock and flush degas bottle?
The section with the hose clamps looks like the heater control valve was removed.
Is there a heater control valve in the lines just outside the view in the pic?
Also, the 2 vacuum hoses in the lower right corner of the pic are looking a bit aged.
I lengthened/replaced/rerouted all the lines to gain access to the plugs/COPs/IAC.
The 2 connections at the firewall are the heater supply/return.
I cut the one off and used a brass 5/8" barb into a 45 deg elbow to angle it away from the engine.
Here's the PVC line -
redman84
26
06-13-2014 06:03 PM
38-72
05-14-2012 06:31 PM
