School me on CDR
It'll probably just use more oil than otherwise... about what you are using now.
Why? Because it's sucking in oil vapor and burning it(which it does to some extent with a working CDR), but it'll do it worse because it won't close down at higher RPMs where there is more suction.
Are you sure the diaphragm is gone? It rests against the back of the valve and the default position it wide open both ways:
Here is a good thread on the CDR with pics: What is a CDR?
No I guess I'm not sure then. I looked as best as I could and couldn't see the diaphragm but I figured since I could blow through it freely it was probably bad. I expected it to default to closed.
the CDR only works well with stock like filter assembles, as the engine operates unburnt fuel and combustion gases leak passed the rings, when not removed they condense on internal surfaces and break down the oil, good venting is always a plus, road draft tubes are a alternative when modified intake systems are used, some persons believe that the gases returned buy the CDR will hurt combustion as they have a lower oxygen content, IMO that it does not. the CDR was also installed to keep oil smell and fumes, from stinking up the vehicle
jasindude1
04-16-2016 04:24 AM
hster
07-19-2004 07:58 PM
