89 F-150 Headlight Relay Upgrade!
Hi,
I did the 3G Alternator upgrade and saw where I could do a Headlight up grade to a 9007 bulb.
However I think I will need to go to a relay set up so I don't burn my switch?
Does anyone have any info on how to do this?
I've Googled but not finding much????
I have the LMC relay kit in my '87.
Cheap little relays, but it takes the load off the headlamp switch and dash wiring. It also provides a better ground for each side. (if you sand the paint off and grease the attachment point)
Buy a spare relay from somewhere else -Amazon for me- LMC are way too proud of them.
Hi,
Thanks!
If I get this relay kit do I have to put in new bulb recepticles for the 9007 bulb????
Not sure how the bulb change works?
Not looking for HID but just something brighter? Thanks!
https://www.amazon.com/Kensun-Conver...+relay+upgrade
Thanks!
Just adding the headlight relay kit is going to make a big difference in how bright your headlights are.
I haven't swapped bulbs, because the 9007 puts the axial filament in a different relationship to the reflector than the 9004's horizontal filament.
repinning the sockets is not difficult, but I have to wonder what it does to the pattern.
I think that harness you linked is for running hid ballasts, not going to np29 bases.
Hi,
Ok, if I just connect in a relay I should get brighter lights from the power coming off the battery!
How about this relay???
1987-1991 Ford Bronco and F-Series Truck Heavy Duty Headlight Harness-Broncograveyard.com
Hi,
Thanks!
I guess that is all I need to upgrade?
I can't even find a tutorial on wiring this up?
I guess it comes with instructions?
Funny when I did the 3G conversion there was info everywhere???
I'll put in this relay and see how that works?
I guess if you want to go to a 9007 bulb you just wire in new 9007 recepticles and your good to go???
Thanks!
I highly recommend Tony at https://ceautoelectricsupply.com/
I used his grounding kit and headlight harness, and custom battery cables, best quality I've found so far.
His headlight harness fit really good on my 92 f150. His custom battery cables. You can see the hella relays on the fender.
Battery cables.
Headlight relay harness kit.
Grounding kit.
Battery cables.
Grounding kit.
Hi,
Thanks!
Thanks!
Installing the relay kit is straightforward. The passenger side socket connects to the harness and the relays get screwed down near the starter relay, then the relay power wires go to the battery+ side of the starter relay.
The ground from each new headlamp socket can be screwed to bare metal on the fenders or radiator support.
Tony's stuff looks really nice.
Maybe he is our new RJM?
Cube (Bosch style) relays would take a lot of my uncertainty out of keeping spares for the other kits.
You could just buy the 9004 harness, though and get a set of Sylvania Silverstar Ultra bulbs. No mods to your existing harness needed.
It looks like you buy the harness pre-configured for 9007 bulbs. It's the former headlight plug on the passenger side that would have to be reconfigured to 9007.
Thanks that sounds like a plan.
I'll get more light from just going with the relay harness anyway and then go with the better bulbs later!
I want to thank everyone here for sharing their knowledge and helping me out!
I'm going to keep my old truck and want to upgrade what I can along and along!!!
Though it seems Ray knows of relay harnesses that are already set up for the 9007 bulbs.
I'm just behind the times, i guess.
