Synchro 4 Speed 1951
Old 10-30-2016, 09:50 AM
eberf's Avatar
eberf
eberf is offline
So I was looking in the owners manual for my 1951 F2 and I found that a syncro Silent 4 speed was offered on the F4-F7
Does anybody have one and will it fit my F2
Old 10-30-2016, 11:53 AM
682bear's Avatar
682bear
682bear is offline
My '51 F2 had the synchro 4 speed and flathead V8 in it when I bought it... so yes, it will fit.
-Bear
Old 10-30-2016, 08:01 PM
cstempert's Avatar
cstempert
cstempert is offline
Originally Posted by eberf
So I was looking in the owners manual for my 1951 F2 and I found that a syncro Silent 4 speed was offered on the F4-F7 Does anybody have one and will it fit my F2
It will bolt in
First, you will need to find one
Then,
You will need to shorten driveshaft
You will need to raise the clutch equalizer ball
It will be slightly closer to the floor
Old 10-30-2016, 08:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
-Bear
That was not a factory option, so someone must have done some modifications to fit the T98 in there. It's quite a bit longer than any of the regular F-2 trannies.
Old 10-30-2016, 09:04 PM
682bear's Avatar
682bear
682bear is offline
Right... I don't know for sure what all has to be modified, but my truck didn't have a driveshaft in it when I bought it... the driveshafts (2 piece) were laying in the bed. It didn't run, so I never tried to install them to see if they would fit.
-Bear
Old 10-30-2016, 09:09 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
Originally Posted by cstempert
It will bolt in
Then,
Why would he need to raise the clutch equalizer ball? The clutch release shaft is in the same position in the transmission half bell. I actually had to raise the rear of the T98 I installed in my F4 as the rear mounting foot is 3/8" shorter on my T98 than on the T9 I took out, measured from the shaft centerline to the bottom of the foot.
Mark
Ar. Hillbilly
11-15-2023 10:38 PM
farmall_7
04-25-2016 05:59 PM
jbarefoot
08-08-2011 11:51 AM
NEWT92
01-06-2008 10:15 PM
Widall
03-29-2005 08:43 PM
Quick Reply: Synchro 4 Speed 1951
