No cruise. No horn. No factory air bags
Old 10-30-2016, 09:03 AM
wevie's Avatar
wevie
wevie is offline
I don't have a clock spring. Let's get that out first. 1995 f250 without airbags.
Ok. Cruise don't work. Horn don't work.
At connector c234 - at cruise servo....
Pins 10 - 7 has 12 volts.
Pin 4 - 10 no voltage.
Pin 5 - 10 no voltage with cruise switch off. No voltage with cruise switch on.
I believe something is wrong in the steering wheel / column which isn't allowing cruise nor horn voltages to pass through.
This is a non air bag truck so no clock spring.
There must be something else behind the wheel that does the job of the clock spring... slip rings or ???
Should I pull the steering wheel?
Old 10-30-2016, 09:19 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
Have you checked the fuses?
Old 10-30-2016, 09:39 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,345 Likes on 1,062 Posts
There should still be a clock spring to allow you to turn the wheel and have electrical contact unless it still used the older style pins that worked like brushes. Pull the steering wheel and look.
Old 10-30-2016, 09:58 AM
wevie's Avatar
wevie
wevie is offline
Yes. All fuses test good
Old 10-30-2016, 09:59 AM
wevie's Avatar
wevie
wevie is offline
Gotta be something but only clock springs listed are for air bag tricks
Old 10-31-2016, 08:45 PM
Scndsin's Avatar
Scndsin
Scndsin is online now
Actually, there was a recent thread about this. There is/was a replacement for non air bag trucks. Seems as though the guy who was looking couldn't find one either & used an air bag CS, but I think he modded it and/or clipped the non-needed lead. Pretty sure it was this year.
Old 11-01-2016, 07:48 AM
subford's Avatar
subford
subford is online now
All 1992-1997 OBS F-series truck without air bags should be the same as I have two from different years. You may have a bad wheel plug or dirty brushes.
Brushes:
Switches and the plug:
Old 11-01-2016, 07:54 AM
wevie's Avatar
wevie
wevie is offline
Found this thread with good information. I'll follow the diagnostic steps there later today:
https://www.ford-trucks.com/forums/1...e-control.html
Doesn't sound like the thread you were referring to.
Old 11-01-2016, 08:35 AM
Scndsin's Avatar
Scndsin
Yeah, I think that was it. We never got a resolution reply on that one. But there could be another thread... Not like there are so few threads on this forum to keep up with in one's brain.
Congratulations on finding it, though. Hope it gives you something to work with & maybe some more response help.
Good luck & keep us apprised regardless.
Old 11-01-2016, 08:37 AM
BLDTruth's Avatar
BLDTruth
BLDTruth is offline
My nephew has the same problem on his 1995 F350. No cruise and no horn. We haven't really dug into it yet so I will be curious to see what you find out.
Old 11-01-2016, 05:48 PM
wevie's Avatar
wevie
wevie is offline
I'm gonna guess that subford is correct and those pictures definitely help. Now if I could find my steering wheel puller.....
Old 11-01-2016, 06:04 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Why?
Loosen the nut then grab both sides of the wheel, start pulling towards you. Wiggle back and forth a few times. Boom....done.
Continue removing the nut.
The keyword is LOOSEN the nut on the steering wheel a few turns. Leave it in place. Once the steering wheel is loose, then remove it.
Worked fine for me for over 35 years.
Old 11-02-2016, 06:10 PM
wevie's Avatar
wevie
wevie is offline
No luck yet. Pulled the wheel and cleaned the pins and slip rings.
Reusing everything I have high resistance on the set button. So that indicates a faulty switch. Now I can't seem to find one.
I've found a part number SW5878 but am unable to locate the switch available anywhere
Old 11-02-2016, 06:13 PM
wevie's Avatar
wevie
wevie is offline
Retesting everything is what that should say
LoyBaird
1997 - 2003 F150
04-06-2014 09:35 PM
manibusan
Electrical Systems/Wiring
11-07-2006 04:26 PM
mlee
03-13-2006 11:39 AM
oceanadec25
09-02-2003 03:58 AM
djhuebner
01-27-2003 05:38 AM
Quick Reply: No cruise. No horn. No factory air bags
