94 Ranger-Cranks, but wont start at times - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-23-2003, 08:03 PM
MRattpack MRattpack is offline
MRattpack is starting off with a positive reputation.
Angry 94 Ranger-Cranks, but wont start at times
I have a 1994 Ranger, somtimes it will not start. It will crank and engine will turnover.
It will not start.
I have read many posts in this forum but have not found any that match my problem.
The problem only occurs sometimes.
I have kept a careful diary each time it occurs and it never happens the same way each time. It will happen after a rain, during a hot day or even a cool day. It never quits running while I am driving it. I can always drive to where I am going and when I go to get back into it, it sometimes will not start, the engine will crank and turnover but it will not start. It has happend after 20 minutes of off time up to 8 hours of off time.
I know this is a bad problem due to it being intermittent.
Does anyone know where I could get good wirng diagrams, I already have the Haynes book. Wondering if I could find any better ones.
Any help anyone could give me would be greatly appreciated.
Thanks in advance for your help.
MR
Old 08-23-2003, 08:34 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!
The first thing I would do is determine if the no-start is due to a lack of fuel or spark. Do you hear the fuel pump run when you turn the key on when this happens?
Old 08-23-2003, 09:21 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
I would replace the fuel pump relay on the left fender. Mine would do the same thing, bought a fuel pump tester and always had right pressure until it bled down. R&Rd the relay no more problems (knock-knock on wood).
Hank
Old 08-24-2003, 12:31 PM
Thanks for the Replies.
Here is a little more info,
I have tried to listen for the feul pump and power relays to click.At different times I have heard the feul pump come on and other times it would not run at all. Plus the relays would click and sometimes not click. It has been hard for me to do this myself and listen at the same time that I am turning the key.
I just had it taken to a repair shop and after it was towed to the shop, the mechanic put the key in and it strated right up. Starting think it may be a electrical connection.
I have purchased a new relay and geuss all I can do know is wiat for it to happen again and try some of the other items that everyone has suggested to me.
Repair shop told me to take a plug wire and ground it to metal and look for a spark and then also try shooting ether in the brether intake to determine if it is elecrical or feul problem.
I just had them give it a tune up, plugs, wires, fuel filter, and PVC valve. I did this because it was about 60K miles ago since the last time it was done. Truck runs good and strong for a V6 4.0 Liter.
Just more details, if anyone thinks of anything I should or should not try, please let me know.
Thanks again,
MR
Old 08-28-2003, 09:51 AM
Bubs39 Bubs39 is offline
Bubs39 is starting off with a positive reputation.
Try replacing the ECC relay, which is close to the fuel pump relay. I had all kinds of problems, replaced many parts, even the computer, all pointed to the fuel pump/ignition. With no codes showing. Even though that relay worked and operated, sometimes it wouldn't let the power through to the computer, keeping the fuel pump and ignition from working, although the engine would crank.
Old 08-28-2003, 09:57 AM
MSRanger MSRanger is offline
MSRanger is starting off with a positive reputation.
The fact that it never lets you down while running suggests that a loose connection is less likely than a failing relay or control.
2006 Ford F350 6.0 diesel INTERMITTENT no crank JC155 6.0L Power Stroke Diesel 7 09-13-2016 11:56 PM
6.0 full power no start. Was cranking and POPED BrandonLee 6.0L Power Stroke Diesel 34 04-11-2016 07:24 PM
Ranger stalling Artemis Gentry Ranger & B-Series 10 01-31-2014 10:05 PM
Quirky start-up FlyingHigh85 Ranger & B-Series 9 10-31-2013 10:50 PM
Starting whine (spin out) SC'79 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-12-2012 12:01 AM
Tags
2000, 2001, 94, clicking, cranks, eec, ford, fuel, ranger, relay, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
