2014 and 34" tires installed
Hello all,
I just got back from getting my Falken WildPeak A/T3W LT285/75-17 E10 ply tires installed. ....ZERO rubbing!
the tire specs from web site is:
LT285/75R17 E/10 121/118S
Overall Diameter 33.9"
section Width 11.1"
revs/ mile 617 (speedo is 10% high. 50 indicated is 55 GPS)
tread width 8.7"
tread Depth 18/32"
weight 65.5 Lbs
Max PSI 80
Max Load 3195 each
I asked to have the RED dot clocked to the valve stem and they balanced with minimal weights on rim.
First impression on ride home is that they are very quiet and rolled well. they are very smooth driving down the road with 50 psi in each.
truck is a 2014 XLT, ECO, Screw 6.5 box .... Fleet vehicle (LT tires, block heater, back up beeper)
section Width 11.1"
tread width 8.7"
tread Depth 18/32"
weight 65.5 Lbs
Max PSI 80
Max Load 3195 each
mileage .... I have none, even w/ 3.31 gears. But that was before the tires. I average about 14 even. I've reset throttle, clean K&N air cleaner, drilled the hole in air cooler, and have a 3" cat back w/ open muffler.
I live in hill country.
If I get into flat land, I have averaged 23 mpg w/ these tires.
my tires are rub free, in all positions now that I zip tied the passenger inner wheel well liner in the position it should have been in from factory.
jonnydz
1999 to 2016 Super Duty
06-22-2013 10:21 PM
