Ford Emblem nuts
Old 10-28-2016, 08:21 AM
70FE250's Avatar
70FE250
70FE250 is offline
Ford Emblem nuts
Is there anywhere online that sells the nuts for my Ford hood letters and the emblem on the side of the hood? I wish to mount all of them back on but I somehow lost the bolts to mount them. Or else is there some bolts I can pick up at menards or lowes that work? I haven´t been able to find the bolts yet without buying everything new
Old 10-28-2016, 08:32 AM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Hit the bone yard. Any ford hood letters should use the same nuts you are looking for
Old 10-28-2016, 09:29 AM
70FE250's Avatar
70FE250
70FE250 is offline
I have tried that also. Unfortunately, North Dakotans consider the emblems a treasure apparently and I could not find any lettering or bolts to use, also considering the fact there´s maybe 6 fords with the suitable lettering at the closest yard to me
Old 10-28-2016, 09:31 AM
orich's Avatar
orich
orich is offline
I found some emblem nuts on ebay. I guess you have not check online.
Also saw some of the rubber backed emblem type nuts at Lowes & Ace hardware type stores.
Orich
Old 10-28-2016, 09:33 AM
70FE250's Avatar
70FE250
70FE250 is offline
Orich
There´s a thing about me, I have an unnatural distrust for ebay so I usually avoid it at all costs. Had a friend get scammed over a part for a vehicle so I try to stay away. But maybe I will try ebay out for these
Old 10-28-2016, 09:39 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Try AMK. Put in your truck info, and hit submit. If you look down this list, you will see a listing for NAMEPLATES @ HOOD SIDES, these might be what your looking for. Not sure if those same nuts will work for the letters on the hood.
Ford Fastener Kits
The following users liked this post:
Old 10-28-2016, 10:45 AM
Brian1971f100
So I guess the proper name for these are "speed nuts" I see summit racing has 3/16" speed nuts looks like they are about $2.00 each. Ouch that's pricey they should be a 20 pack for that price. They are listed as emblem nuts. OER Emblem Speed Nuts 11501047
Old 10-28-2016, 11:06 AM
67nukeford's Avatar
67nukeford
I wonder if you could find these at an Ace Hardware store, they carry a lot of automotive fasteners. Even Lowes carries some.
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
373888-S78 .. 1/8" Spring Nut-FORD Letters to Hood / Obsolete
1970/72 F100/750 & Econoline.
No Ford dealer or obsolete parts vendor has any.
371024-S7 .. 1/4" Self Threading Nut=Emblem to Hood Side / Obsolete
1968/72 F100/750.
OBSOLETE RELIABLE PARTS in Nashville GA has 3 = 229-686-5101.
Old 10-28-2016, 11:07 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
For 70/72 the hood letter 1/8" spring nuts were part number 373888-S7-8. The hood side emblem nuts were part number 371882-S7. There are none of either of these on my locators.
And OP, not trying to beat you up but you need to call a part the correct name if you are ever to find it. Bolts are male. Nuts are female.
Old 10-28-2016, 11:22 AM
rechinca's Avatar
rechinca
rechinca is offline
Yes you can find these at ACE Hardware or any decent hardware store that sells nuts, bolts, etc by the piece.
Old 10-28-2016, 02:46 PM
70FE250's Avatar
70FE250
70FE250 is offline
Yes, I did not get any sleep last night so my brain is operating at 2% how it normally does. I found macs sold the nuts online so I may attempt to purchase some if they are the right size
Old 10-28-2016, 05:32 PM
lilorbie's Avatar
lilorbie
lilorbie is offline
Ford Emblem nuts
70FE250 if you have a PPG paint store close to where you live they have what you are looking for. i needed some barrel nuts to hold the letters across the front of my 67, they said here their free. now you might not get that good of a deal, but you never know.
Old 10-28-2016, 05:52 PM
artscott61's Avatar
artscott61
artscott61 is offline
go to a body shop
PapaBearYuma
01-26-2017 06:16 PM
52 Merc
01-16-2013 10:00 AM
medicpg
07-31-2008 02:06 PM
sparky
39
11-01-2006 06:07 PM
Quick Reply: Ford Emblem nuts
