what year 302 engines can I put in 74 e100 van
Couldn't he just swap the timing cover and fuel pump eccentric off his original engine? All he'd be out is some time and a couple gaskets & a seal. Nothing real complicated or expensive.
I have taken a efi 5.0 out of a Lincoln Towncar and put on older alum front engine cap and the fuel pump eccentric and ran a regular mechanical fuel pump on an old F100.
Sometimes vans and cars have different sumps and oil pans, but just like the mechanical fuel pump, nothing you probably can't swap around. I'm not sure the engine is close enough to crossmember to have any oil pan issues though, I'd think any would probably work.
Someone I know from elsewhere put an 5.0 HO from a 90's Mustang in his 72 E100, be sure to run the correct distributor drive gear on a roller cam, the cast iron gear on your vans unit will eat the cam, you will need to run the vans oil pickup and oil pan also.
It's the other way round, the steel cam is harder than the cast gear. So the gear will get worn, not the cam.
ford5t6
01-25-2008 10:36 AM
robertbourque
01-30-2007 11:44 PM
econoline_dude
10-29-2002 10:14 PM
GEAH
07-23-2002 05:35 PM
sargroup5
05-26-2001 10:24 PM
