Rear drawer set up build/need some advice
Started a rear drawer set up for the ex for camping and sleeping. Everything is built out of 3/4 Baltic birch. Goes from the rear doors to the back of the second row seats and behind the seats has a compartment for 3 back up batterys which later will be hooked up to solar and the small holes on the bottom of both sides will get air and electric down the road. So i can air tires back up and so i can run 120v items. Here is what everything looks like so far
Now here is where i am stuck. I need some kind of drawer sliders that are around 48in long. I found this site that has some but i dont know how they will last http://truck-hardware.orrorr.com/vie...tension-slide?
Any suggestions are welcome. Trying to stay around 120 a pair since i need 2 pairs.
Originally Posted by Stewart_H
Check out the builds in the tech folder and see what they used.
Stewart
Stewart
The slides you linked to are meant to attach to a metal drawer via a slot and tab system like in a tool box and are not the lockout type which means unless your vehicle is perfectly level the draw will either be trying to close or open making it a royal PITA to use. I would use a lock out style slide and one that screws or bolts to your cabinet.
Orr & Orr has lockouts and they appear to be made by Ryadon.
Heavy Duty Drawer Slides »
Lock out
http://truck-hardware.orrorr.com/vie...xtension-slide
Lock out
Hettich makes an industrial grade lock in, lock out slide in their ka3338 series but it only goes up to 40"
Top quality stuff
https://www.hettich.com/fileadmin/co...e_0311_HUS.pdf
available here
Hettich KA 3338 Locking Drawer Slides
Top quality stuff
available here
Accuride supplies the slides to snap on, military and industry but they are $$$$
The 9308 series would be cool if you can find a deal on some used ones
https://www.accuride.com/en-us/produ...=&modelNumber=
Top quality stuff
available here
Top quality stuff
available here
Lock out
Lock out
Originally Posted by SmackDaddy
I am planning on doing something similar with drop down boxes with a lid right behind the second row seats and where it steps up will be where the slide out starts. Subscribed!
https://www.ford-trucks.com/forums/1...l#post14801777
KV 8900 Series Full Extension Precision Ball Bearing Slides 40" 500# Class (Set)
Amazon, $179.95 for a set
...you can probably get a set that has a lower weight rating if you aren't carrying the type of gear I do (sledge, axe, demo bar, pry bar, bolt cutters, hand tool sets, chains, etc. etc.).
Another thought before you get too far down the road...have you thought about linear bearings? Like the stuff 80/20 makes?
https://8020.net/catalog/category/vi.../837/?cat=1345
You'd mount sections of extruded aluminum either on the sides of the drawers or even the bottoms...connect them using the linear slide bearings.
