First coolant filter change
Old 10-27-2016, 11:44 AM
iverger's Avatar
iverger
iverger is offline
Last July I installed a coolant filter kit from dieselsite, did a full flush and switched to Rotella Red with RMI-25 instead of SCAs.
I went on an 5k mile trip and last week I changed the 1st filter out (about 6k miles total). Thought all y'all might be interested in seeing what the insides looked like.
Old 10-27-2016, 12:30 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
https://www.bobistheoilguy.com/forum...94#Post3061494
interesting read, RMI is supposed to clean out crud and looks like it did on yours
Old 10-27-2016, 12:50 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Jaaaaaaackman is offline
Wow nasty, where does that come from , is something not quite right?
Old 10-27-2016, 01:20 PM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...l#post15268989
18 months ago OP had 185k on motor, my guess it cleaned out a lot of stuff that built up over the years and maybe should have checked that filter sooner
Old 10-27-2016, 03:10 PM
lee00's Avatar
lee00
lee00 is offline
Everything I have read says if you have not had a coolant filter to start doing coolant filter change early and often as it will plug up...
first at 500
send at 1000
third at 3000
and depending on how dirty every 5000 after that.
Old 10-27-2016, 04:12 PM
iverger's Avatar
iverger
iverger is offline
That's an understatement. I should have had a filter on it long ago also. The coolant prior to change was not that old, I flushed and filled when I bought it at 170k (I think ford recommends every 30K). Flushed it again when I changed it 6K ago. It was still dirtier than I expected but I guess the RMI-25 is doing it's job and cleaning things up quite well. From what I've read some of that sludge is it cleaning up the SCA buildup as well.
The RMI literature recommended changing the filter 3 times in the first year and annually after that. Since the average soul drives 12k/yr I equated that to changing it every 4k the 1st 3 times. Live and learn.
Needless to say I have a lot less crap in my system then I did one filter ago and I'm sure to have even less in another filter from now.
It's all been educational.
Old 10-28-2016, 09:30 AM
knottyrope's Avatar
knottyrope
thanks for letting us know your experience, its good to learn from others
I am going to do a coolant change after winter and a bunch of other things needed
Old 10-28-2016, 10:28 AM
BBuford1962's Avatar
BBuford1962
BBuford1962 is offline
Interesting read...good information...I need a coolant filter!
Old 10-28-2016, 01:38 PM
iverger's Avatar
iverger
iverger is offline
first at 500
send at 1000
third at 3000
Not sure about the open systems but for the closed systems like my 97 has the dieselsite kit is not hard inline, if the makes sense. It feeds from an unused plug just below the thermostat and T's into the return line of the reservoir. The upside being, if it does plug up the system just reverts to its non-filtered self. No harm, no foul and no overheating.
Bob
Old 11-05-2016, 06:36 PM
Airstreamer67's Avatar
Airstreamer67
Airstreamer67 is offline
I've got my filter plumbed as a paralleling bypass on the incoming heater line. As with yours, if the filter plugs before I can change it, no problems.
Old 11-05-2016, 08:15 PM
PSU4ME's Avatar
PSU4ME
PSU4ME is offline
Got mine installed yesterday.
Old 11-07-2016, 02:43 PM
knottyrope's Avatar
knottyrope
nice install, I like it
Old 11-07-2016, 03:20 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Would that location interfere with IC piping?
Old 12-15-2016, 04:11 PM
mcali2's Avatar
mcali2
mcali2 is offline
Because I cant remember anything where do I get replacement filters? I have the kit shown above ^^^^^^
Old 12-15-2016, 04:16 PM
knottyrope's Avatar
knottyrope
Quick Reply: First coolant filter change
