Eletrical Issues with 95 F-350SD Diesel Start and Run.
Old 10-25-2016, 07:58 PM
Texasdeereandhorse's Avatar
Texasdeereandhorse
Texasdeereandhorse is offline
Hey everyone, I really need some help with this one. A friend of had her 1995 7.3 F-350SD tire truck stolen by her ex-husband. He tore the ignition lock out of the column and got the ignition switch into run, but didn't know how to get it to start, not a bright guy I guess. So he added a ON/OFF switch to the starting solenoid to start the truck. To turn off the truck, he would unhook the batteries. At some point he must have blown the 30Amp Mega fuss under the hood that controls the PCM and didn't know why it wouldn't start anymore and burnt up the starter. 3 months later the owner has got the truck back and I have been working on it in my free time to rebuild the steering column and found the fuse #22 blown. The truck started right up and ran for a few minutes, then quit running like you turned the key off and relay#2 is now chattering when the key is on. That relay is for the fuel pump from what I have found, but I thought this model truck had a mechanical fuel pump? What happened and why is the relay chattering now, did I miss something?
Thanks in Advance for all your help as her other truck is now having issues and she needs this truck for her tire business.
Old 10-25-2016, 08:55 PM
PSU4ME's Avatar
PSU4ME
PSU4ME is offline
Is the #22 fuse still blowing? If so, I think that powers the PCM as well. If it's bowing it could be the fuel heater on the bowl, most recommend unplugging that.
Also, make sure all yours grounds are good. I had the clicking delay and it turned out to be the ground by the E brake
Old 10-25-2016, 09:36 PM
Texasdeereandhorse
Thanks, I'll look at the grounds.
Fuse #22 fuse does supply power to the PCM, but it hasn't blown again.
Relay #2 says from what I've read is for the fuel pump? It's the relay that's chattering and now the truck wont run link the fuel is shut off again?
Old 10-26-2016, 08:31 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
do you have efuel? if not then there is no relay for a mechanical pump
Old 10-26-2016, 09:19 AM
farmert's Avatar
farmert
farmert is offline
My manual says relay #2 is for the IDM on a diesel. On a gasser, it is for the fuel pump. You must be looking at a gasser manual.
Old 10-26-2016, 09:25 AM
knottyrope's Avatar
knottyrope
swap that relay 2 out with horn relay and see if it stops chattering
Old 10-26-2016, 09:53 AM
PSU4ME's Avatar
PSU4ME
PSU4ME is offline
I had this same issue.......it wasn't the relay rather a bad ground. Swap the relays as knotty said but i got $8.50 it does the same.
+1 to farmert, you are prob looking at the gasser
Old 10-26-2016, 09:58 AM
PSU4ME's Avatar
PSU4ME
PSU4ME is offline
here was mine:
Old 10-26-2016, 01:22 PM
madpogue's Avatar
madpogue
madpogue is offline
^^^^^^ +1; Chattering relay is almost never a relay problem. It's just the symptom. Typical voltage/ground issue. Turn the key, the relay closes, whatever it powers energizes, but with the connection issue, that draw pulls the circuit voltage down. This causes the relay to open. Open relay, no more load on that circuit, the voltage can recover. This allows the relay to close again and the load to power up again. Lather, rinse, repeat (several times a second).
Check main battery connections, connections to PCM / IDM, GP circuit and all grounds.
NinetyFiveF150
19
03-13-2017 07:44 PM
michaelscott58
15
02-27-2014 01:13 PM
Pinky Demon
1999 to 2016 Super Duty
05-01-2009 09:56 PM
Webslinger
26
09-17-2007 06:09 PM
slammindeuce
1983 - 2012 Ranger & B-Series
12-17-2001 11:21 AM
Quick Reply: Eletrical Issues with 95 F-350SD Diesel Start and Run.
