I have found this to be a problem on two restorations, both 1951 F1 trucks. Parts were all new, and from various different sources each time. See photo, the hose crimping rubs the cap of the new king pin. The new wheel cylinder should or could have a better angle, or the hose crip a smaller diameter. In each case, the truck came apart with the same poor clearance. Anyone else have this?
I literally had started a post of this last night. I was wondering if it was the wrong hose, or ???. I got one from LMC and another from O'Reilly's and they were exactly the same. I used my vice grips to squeeze them tighter, but still barely rubs. I assumed they will wear there own path, it shouldn't hit the hose itself.
Yes, they are on 48-52 also, but if I switched them, the hose would point to the front, away from the frame mount. All photos that I have ever seen show hose exiting toward back.
Backing plate would stay. But the hose angle then would not be good. Plus, in two recent trucks, that were very original 40+ year parked, hoses all pointed to the rear.
Remove everything off the backing plates and set it on the ground leaving on the side it was on. Then remove backing plates and swap sides. Then reinstall wheel cylinders etc
