Tire and Wheel Combinations with Mustang II and Rear Leaf Spring Kit
Hi all,
I recently purchased a Heidts Mustang II front end with the two inch drop spindles from JPL for my '52. I plan on buying a rear leaf spring kit which should lower the rear end around 4" as well (Explorer 8.8). What tire and wheel combinations have any of you used with a similar combination? Do you have any photos? I want to go ahead and buy the tires and wheels so I can roll the chassis with the new 5x4.5 bolt pattern but want to make sure I don't have any clearance issues. Any help would be appreciated.
Thanks
Thanks
Have you tried the tool on the Midfifty website? You can play around with different backspacing etc. Just bear mind it is set up for 60" axle and not the 59.5" you have. You are further along than me so can't help any more than that. Sorry. I created sizes to aim for with a similar set up to yours but I could not tell you with any certainty whether they will work or not.
TritonBeast
01-22-2018 09:34 PM
1951flatheaddave
09-30-2011 12:52 PM
1951flatheaddave
09-30-2011 11:29 AM
