Starter bolt sizes - Ford Truck Enthusiasts Forums
Starter bolt sizes
Old 08-23-2003, 03:41 PM
visaggio visaggio is offline
visaggio is starting off with a positive reputation.
Starter bolt sizes
I've got an 85 ranger 4x4. 2.8v6 that i picked up for nothing. Needs a LOT of work. Decided to start with the starter (pun intended) as it didn't have one.
I've got the starter, but i'm trying to figure out what size and thread of bolt I need to install it.
Auto parts store was unable to help, and local ford dealer's service dept. is closed on weekends (go figure). Anyone know off hand, or able to point me to a good reference?
Old 08-23-2003, 06:25 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Starter bolt sizes
I would hate to guess since half of them are metric now. I would eyeball some of the other bolts on the engine (like a alt bracket bolt or something), and see if it will fit thread wise. It should have a good fit in the threads, with no slop. If you do find one that fits, measure how thick the starter flange is, and get a bolt twice that thickness(approximately). Take the bolt that fits down to the hardware store, and try their selection of nuts till one fits. Then you will know the thread pitch and if it's metric, and then you will know what bolt to buy.
Old 08-23-2003, 10:31 PM
Starter bolt sizes
i suppose that's what i'll have to do. I think i've got a can of bolts around somewhere, perhaps i'll just have to dig through that.
Thanks for the advice.
5.4 starter bolt size/thread pitch Partsjockey 1997 - 2003 F150 0 06-14-2013 08:36 AM
starter bolt size thedieselkid Modular V10 (6.8l) 1 05-08-2012 07:08 AM
1969 f250 starter removal BIGREDBULLDOZER 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-29-2008 03:43 AM
Tranny swap-starter problem! Help! Polkat Clutch, Transmission, Differential, Axle & Transfer Case 6 09-15-2005 08:20 AM
starter bolt size gsx Ford Inline Six, 200, 250, 4.9L / 300 5 01-08-2003 01:30 AM
Tags
73, bolt, ford, size, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
