97 -2003 5.4 engine swap
Old 10-24-2016, 07:03 PM
Heavyhead's Avatar
Heavyhead
Heavyhead is offline
I have a 2003 f 150 5.4 L is eighth digit of vin
268000 miles . I have a head gasket problem .
I have a 97 5.4 truck with broken frame only 100 k.
Can i swap motors with no problems?
Old 10-24-2016, 11:22 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,579 Likes on 1,288 Posts
Welcome to FTE.
I do not know the specific changes made between '97 and '03, but they are probably different enough that running the older motor with the new computer could be an issue. Note the power differences:
Ford 4.6L & 5.4L Specs | Ford Modular V-8
235 HP to 260 HP would be some changes in heads and cam I think. I know the 4.6 went to "Performance Improved" heads during this time, not sure if it's the same tweak with the 5.4.
Now this is a lousy answer but it bumps your post up so stand by.
Dawgbite14
1997 - 2003 F150
10-14-2016 12:13 PM
RobRoe
1997 - 2003 F150
10-21-2008 07:32 AM
desotodan
1997 - 2003 F150
05-11-2008 09:07 PM
snod_ix
1997 - 2003 F150
02-21-2008 10:32 PM
culprit2
Modular V8 (4.6L, 5.4L)
09-23-2003 01:37 PM
Quick Reply: 97 -2003 5.4 engine swap
