Flareside wood & bed refurb, seeking some quick part advice
Old 10-24-2016, 03:17 PM
tontokowalski13's Avatar
tontokowalski13
tontokowalski13 is offline
Hello,
I'm attempting to replace the wooden bed in my 1985 F150. Everything is pretty far gone, so the parts list is getting long. AND, most is available online through MarK or other retailers. But, I just discovered this yesterday and I'm not sure what it's called or who would actually carry a replacement part.
There are these small panels on the very rear bottom of my bed. They are probably 12" x 10" and they are completely rusted through where the top would attach to the bed-walls.
Any idea what they are and who sells replacement parts? I looked on Mar K and do not see them.
Pictures are below, advice is greatly appreciated.
Thanks,
JT
Old 10-24-2016, 05:42 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
WhatsAChevy? is offline
Maybe SCFlareside can weigh in on this. I do believe he has been down this road.
Old 10-24-2016, 06:04 PM
bcamill's Avatar
bcamill
bcamill is offline
OK, you are not going to be able to purchase those along with the side panels unless you find them in the junk yard or EBAY. Those small parts are just sheet metal and can be made and bent with a brake. Welding is involved of course, so if you are not a welder, you can get a shop to do it. They all liked to rust there.
Old 10-24-2016, 08:00 PM
reamer's Avatar
reamer
reamer is offline
they are filler plates, as said just bend 2 lips on straight sheet metal and your good to go....
Old 10-25-2016, 08:58 AM
Tonto Kowalski's Avatar
Tonto Kowalski
Tonto Kowalski is offline
Sounds like it might be a job for a professional! I'd like to try to attempt that on my own but don't have that equipment (or time)
Any guesses on what fabricating and installing that piece should cost? I can't imagine it would be all THAT expensive, right?
Thanks everyone,
JT
Old 10-25-2016, 11:28 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,104 Likes on 1,792 Posts
See your other post on this you posted I said how it can be done.
Now time I can't help you with but if you find a fix for it please let me know. With the crazy work hours I have I don't have time either!
Dave - - - -
Old 10-25-2016, 12:19 PM
reamer's Avatar
reamer
reamer is offline
I have a brake, can make them fer both of ya..
Old 10-25-2016, 12:56 PM
Tonto Kowalski
Dave - - - -
I didn't see anything there...maybe it didn't go through somehow?
Old 10-25-2016, 01:49 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
AFAIK, most of the Flareside parts reproduced by Mar-K are for 1953/60 F100's w/a 110" wheelbase. Some of these parts also fit 1961/72 F100's with 114" wheelbase.
The panels shown in the pic as basic part number 112B26 (EOTZ-83112B26-A) are the same right & left for 1980/87 Flareside only. No Ford dealer or obsolete parts vendor has any
Old 10-25-2016, 05:45 PM
FuzzFace2's Avatar
FuzzFace2
I made mine for another project I am working on.
I was on my phone and don't know where you posted it but here goes.
You will need flat sheet metal to make the panels from.
You can use a 2x4 and angle iron as a brake. Clamp the iron to the 2x4 with the sheet between them. Make the bend to the angle iron using a hammer bending the sheet a little at a time till you have the 90* you need.
I was lucky that I have a car trailer with a long run that is flat that I put the 2x4 on top of and clamped it down.
Dave ----
Old 10-25-2016, 08:46 PM
reamer's Avatar
reamer
reamer is offline
Hi Number Dummy, 112B26 is the under-bed exhaust heat shield, correct?
He's looking for the "filler" or "extender" where the rear of the fiberglass fenders bolt to. (what is circled in his photo)....
These are Factory Tac-welded to the lower lip of the steel sides. I don't believe these are/were ever available separately.... but simply reproduced......
Old 10-26-2016, 11:19 AM
Tonto Kowalski
You nailed it Reamer...that's exactly what I'm looking for.
Old 10-28-2016, 07:24 AM
reamer's Avatar
reamer
reamer is offline
easily made, just 2-90 degree bends....
Old 10-28-2016, 02:35 PM
SCFlareside's Avatar
SCFlareside
SCFlareside is offline
Agree - even if you don't have welding or metalworking skills, use sheet metal and you can make these!
Some may frown upon this but you could probably even attach these with a rivet gun and be fine. Be sure to take your time and paint every surface including any holes you drill if you use rivets... multiple coats and especially mind the edges. I used sheet metal and rivets on my cab filler plates ahead of the steps and they look good but I am watching closely any rust
Old 10-28-2016, 02:38 PM
SCFlareside
By the way
Your bed actually doesn't look that bad by the way - great that you are catching it now!
jhaas63
06-04-2012 08:26 AM
Riskyguy
06-17-2011 08:06 PM
Sweetsby
02-26-2011 04:02 PM
pinkpanther
09-20-2010 06:09 PM
Justaguy
05-21-2005 07:03 AM
Quick Reply: Flareside wood & bed refurb, seeking some quick part advice
