1997 Extended cab nerf bars or side step
Hey fellas,
I am looking to get some chrome nerf bars or side steps for my 97 extended cab but I am having a hard time finding any.
I see Westin have a set
https://www.realtruck.com/westin-sig...s/25-0620.html
A heads up on other options would be appreciated
Thanxs
Colin
Thanxs
Colin
IMHO neither one looks contemporary to the truck. I'd shop around for some extruded aluminum running boards. I found a set for our SC truck, but they were for a crew cab, so I just cut them down. I did NOT just do the orthodox mount to the cab sheet metal. I built triangular gusseted brackets out of slotted angle-iron, and mounted those to the frame, then ran a reinforcing strap (slotted flat stock) from the brackets up to cab/bed. The reinforcing straps allow for frame-to-cab movement.
Here they are on the SCLB:
This set has a rather tall vertical section, which brings the boards down quite a bit. Never mind the angle; stoopid me measured from the ground up, which didn't take into account the rake (rear is aprx. 1/2" higher).
Our blue RCLB came with a set that has a shorter vertical height, so they sit up higher closer to the cab. Personal preference I guess, how much of a step up vs. how low you want them extending.
Hey fellas,
Thanxs
Colin
Thanxs
Colin
Thanxs for the replies fellas.
That's a very nice offer PW,
can you post a picture so I can see what is involved in making new mounting brackets.
appreciated
Colin
I have a set of the stock fiberglass steps that came off my extended cab. You are welcome to them but you will need to make new mounting brackets as mine rusted off.
appreciated
Colin
Thanxs Brad.
Ya, the 5 speed is good
When I first got the truck I thought the clutch was shot so I bought a new clutch kit, then read on here about the permanent fix, $30 later & all good.
all the best
Colin
all the best
Colin
