No start in cold mornings
I have a 2000 7.3 and the past month I have had a very random issue with my truck not starting in weather below 50. Some mornings when it's below 50 and I plug in the block heater I have no issues. There have been a few morning when I haven't plugged it in and it starts fine then as well. This morning it was about 40 and I didn't plug the heater in and now it wont start. I just replaced the glow plug relay and still wont start.
Once I get it running it runs perfect and starts back every single time. As it cranks it sounds like it's not firing if that makes any sense.
Any help would be greatly appreciated.
First step would be to determine that the GPR is working. When the engine is cold have someone turn the key on but not start and test the right post on the GPR for power. You could also jump across the GPR with a big screwdriver for a minute or more then try to start the truck and see if it starts.
Thanks for all the reply's. What was odd was when I hooked up jumper cables from my wifes suv it started immediately. Unhooked the cables, turned off the truck and it wouldn't start back until I hooked up the cables again. I did go through and clean all the batter connectors very thoroughly and it starts better but it hasn't been cold enough to see if it fixed the issue. I went to autozone and had them test both batteries and they way there were good batteries.
Supa Duty
1999 to 2016 Super Duty
20
03-05-2014 08:46 PM
