Ford 7.3 injector harness issue?
So after hitting a pothole, it would seem like half the engine lost power, after some searching around, i found that i would most likely be the harness inside the valve cover that has lost connection.
Its the right side, so i would need to take of the turbo pipe, and probably something else to get to it.
Since i'm doing this job, is there something else you guys can recommend to check out along the way? I want my 7.3 to be as reliable as possible.
I will probably ask some questions along the way, it can be a challenge sometimes to own a car that not many mechanics are familiar with, but as i have read online, this should be a very straight forward fix.
Can the harness be upgraded so it doesnt happen again? Its an 02
If possible test the injectors first. Since you will have the cover off this would be a good time to replace any that are marginal. If the boots on the turbo air ducts have never been replaced I would go ahead and replace them now. Rubber degrades with age.
There is no better model of harness that I know of. But the original is very good. It lasted 1.5 decades after all in high heat high vibration conditions.
I would replace both harnesses. It is time.
Inspect all of the turbo ducting. If you got a leak from that bump it will feel like your engine lost half its power. But even if you find this is the cause I would still consider replacing the harnesses though you may wish to wait until you need to replace an injector.
I too think its time to change out some components due to age and wear,
i'm basically just sitting waiting for the transmission to fail, not because i suspect anything, but because i expect it at this mileage, 220.000km.
Torque the plates back down too, they tend to work a little loose over time and it really quiets things down.
I just super-glued the damn connectors inside, had them work apart a few times too many and the quarter mod actually wore through one of the arms. Not risking a quarter bouncing around my valve train.
Valve Cover Gasket for Ford 7.3L Powerstroke (99-03)
I am still using my original CAC boots. They will probably outlast the truck so unless yours is torn there is no reason to replace them.
Good idea to change the glow plugs since you are in there. I always use Motorcraft glow plugs. The aftermarket glow plugs have been known to cause problems from time to time. Riff Raff has the glow plugs also....
Might as well check the injector clamp bolts....they can work loose. Make sure they are snug. Careful not to overtighten those things....they can break....(then you'll have another unwanted problem...).
If your truck is 4x4....you can reach the lower bolts on the right side valve cover through the wheel well. If 2x4 then you might have to take the wheel off to get in there. (not sure about that....all my trucks are 4x4...)
Tip for removing and replacing glow plugs...
Loosen glow plugs with 10mm deep well socket and then use a 10cm length of vacuum line to press onto the end of the plug and unscrew. Reverse procedure to reinstall. Make sure the vacuum line fits snug on the end of the glow plug. This will help ensure you don't accidentally drop the plug into the engine valley.
There is a UVCH link in my signature, it's worth a click to make sure you've isolated the problem and confirm the fix. While I wouldn't subscribe to throwing an injector in there without the urgent need for it - it's certainly worth looking into replacing injector O-rings. We are learning that we are crossing a threshold of time, and failed injector O-rings is growing more common. I'm not saying to take this task on no matter what, I'm saying I'd do a little homework on it and mull over it.
I'm still waiting for parts, but i bought new valve cover gaskets, glow plugs, and wiring harness, hope the parts get here by next week. I will check that everything is tight when i'm at it.
Injectors will be replaced sooner or later, the truck will be stripped to the frame and restored, the winter is norway can be harsh, especially for american steel 2015 facelift, lift, some stuff from iceland, and MUCH more, hoping to get around 500hp out of it, with reliability. starting this coming winter Wont be done my though, a proffesional shop abroad will handle all of that
I don't plan to do any big modifications on the engine, so i will see how far i can get
Planing on.
Intake
Exhaust
Chip
Better turbo pipes, remove as many stock restrictions.
Banks turbo upgrade kit
Regulated Fuel Return
Injectors
Studs
Don't know what this will give me, but i don't plan to do any major work on the engine. I'm already sitting waiting for the transmission to fail so i can rebuild it with more durable parts, and a new converter.
I guess its not possible to fit a 5 speed to engine?
Planing on.
Intake
Exhaust
Chip
Injectors
Studs
