cruise control
Old 10-21-2016, 11:48 AM
highoctane74's Avatar
highoctane74
highoctane74 is offline
cruise control
Does anyone have a picture of how they mounted their cruise control to an aftermarket manifold? I can't for the life of me figure out how to put it on.... I took it off 8 years ago.
1979 F150 Ranger Lariat with 460
Thanks.
Old 10-21-2016, 02:57 PM
tbear853's Avatar
tbear853
tbear853 is offline
Received 1,288 Likes on 1,089 Posts
What kind of Cruise Control? Is it OEM or aftermarket? Maybe a picture ???
I ask because I've never seen a OEM one in the flesh, but I have a Sears sold one that I installed in the late '80s, I think it was made by Dana. I had one just like it on my '67 Chevelle SS with the 396 and later with the 454 Tri Power. On my '77 the part that pulls the throttle is a cable, the diaphragm part mounts to the firewall with just one bolt on back. The brain is under my dash and it will disengage with a tap of the brake pedal as it has it's own switch with a chain to a bracket on the firewall that opens vacuum and cuts power to brain.
On that Chevelle, the switch had a pulley like thing I attached at firewall and a ball chain ran from switch lever to firewall and back to clutch so tapping either brake or clutch killed it.
There's some pics at https://www.ford-trucks.com/forums/1...edelbrock.html
Old 10-21-2016, 03:39 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
All I have handy at work. Maybe this will get you in the ball park?
Old 10-22-2016, 06:50 PM
highoctane74
It is the OEM cruise.
Thanks those pictures clear up a few other items I was second guessing.
Here is what I have that has me confused as to where it goes.
​​​​​​​Name:  IMG_20161022_173158_zpsacg91qs3.jpg
Old 10-22-2016, 08:58 PM
orangeford's Avatar
orangeford
orangeford is offline
Hopefully this helps. As far as physically bolting the servo on is has to bolts that go in the intake manifold and one on the back of the cylinder head. For some reason I had to put some spacers on the intake to get the cylinder head hole to line up. I just used oversize nuts as spacers. My 460 has an edelbrock performer intake and the servo/bracket was off a 77 lincoln mark v.
Old 10-23-2016, 10:43 AM
highoctane74
That gives me a great start. I will try fitting it tomorrow and see what I come up with. Thanks for the pictures
Old 10-27-2016, 04:23 PM
highoctane74
Managed to get everything where I think it goes......just missing the part that attaches the chain to the carb....so...close....
Critterhunter
1983 - 2012 Ranger & B-Series
10-30-2014 09:22 AM
kuzco
11-09-2009 08:24 AM
sammydiesel
1999 to 2016 Super Duty
03-17-2009 12:47 PM
woogs
1997 - 2003 F150
10-28-2004 12:00 PM
F350flatbed
Electrical Systems/Wiring
06-01-2003 10:43 AM
Quick Reply: cruise control
