88 f250 battery drain
Battery discharges overnight. Put in new start relay, starter and battery. Also put in new ignition switch but it might have been defective, when I removed key (lock position), the dinger alarm kept going off for a few seconds. Put the old switch back in, charged battery (load test was okay) and truck started (The voltmeter reading on dash gauge was less than 8 volts ! Turned off truck, went out a few hours later and turned key, nothing happened. Any ideas guys?
I'm going with, this is an '88 and likely has the infamous 2G alternator.
No stud to 'touch' the cable to, but a rectangular plug with two black/orange charge wires and a white/black stator wire.
Ford TSB 96-21-4 spells out why this connector should be changed any time you have a charging system issue.
Yes, it could be the diode board inside the alternator causing the draw, but usually the alternator will charge while running.
In this case he has no charge *and* substantial draw (key out)
Chasing a dead battery had me changing this pigtail twice in my truck before I finally got smart and did a 3G conversion.
If you remove the negative battery cable off of the battery hook up a test light (non LED) between the negative post and the cable. It will light up for you if there's a draw.
If you pull and replace the fuses one by one in the fuse box the bulb on the test light should go out once you pull the fuse for the circuit that's causing the draw.
That should help you to pinpoint what might be causing the battery to go dead. I had a hood light killing my battery years ago, I was going crazy for weeks and this was how I found the draw.
Hope this helps out
Tony
Hope this helps out
Tony
burnout01134
1997-2006 Expedition & Navigator
03-18-2016 01:33 PM
rowanspahr
08-25-2007 03:24 PM
