1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2003 F250 5.4 engine comaptibility
Old 10-20-2016, 12:17 PM
kvet's Avatar
kvet
kvet is offline
Hi there. I have a 2003 F250 5.4. Blew a cylinder in it and I am trying to do an engine swap.
I am trying to find a good 5.4 to do the swap. Have come across some F150 5.4's, but I can't seem to find a solid answer on compatibility.
Does someone know the years that could be cross compatible, if they even are? Is there a site that might have some more specific info?
Have already sourced out the local wreckers and have not found a working engine from an F250, but I have a low KM F150 5.4 sitting at one yard. Hoping it will work.
Thanks in advance.
Old 10-20-2016, 03:32 PM
khxor's Avatar
khxor
khxor is online now
Pretty sure that as long as you find a 2 valve PI engine then you can use it; depending on what it came out of you may need to swap over parts from your old engine (oil pan, possibly timing cover, not sure if the intake manifold is the same on an f-150)
Old 10-20-2016, 03:45 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
car-part.com
Old 10-20-2016, 04:29 PM
GN1220's Avatar
GN1220
GN1220 is offline
I just went through this. The intake and exhaust manifolds are different. The 250 doesn't have the egr. And the location of the oil filter and housing are different. Can the filter housing be swapped? That I don't know because I took the F150 engine back and just did the heads on mine.
Old 10-20-2016, 07:29 PM
khxor's Avatar
khxor
khxor is online now
Yes the oil filter housing can be swapped out, I remember doing that when I swapped engines.
ez2bbad64
2004 - 2008 F150
03-03-2016 07:11 PM
whits
Modular V8 (4.6L, 5.4L)
07-11-2009 09:53 PM
44wk
Engine Swaps
02-17-2008 05:32 PM
TPDK97
03-28-2007 10:42 AM
duckcarver
08-23-2002 09:38 PM
Quick Reply: 2003 F250 5.4 engine comaptibility
