Hi, Guys - I'm trying to locate a replacement banjo bolt that attaches the wiper and distributor advance vacuums to the carburetor. My truck is a '46 half ton with a V8 and I haven't been able to find this bolt in the normal catalogs.
After reading this again I am thinking that you could use a T fitting if you can't find a banjo fitting. I was at first thinking you needed the above fitting.
Thanks for the suggestions. Unfortunately, I don't think the bolt you described will work for me. I was hoping that someone had an old carb in the scrap pile or on a junked engine and would be willing to sell me the original bolt from the carb.
I think he is referring to the bolt that goes thru the banjo fitting, which provides vacuum to the dizzy, then the bolt has a vacuum port on the end that accepts the rubber vacuum line for the windshield wiper(s). I don't have a pic but have seen them for sale on eBay.
