98 ford explorer. Theft light flashing, turn over sometimes but shuts back off. How to bypass
Old 10-20-2016, 10:32 AM
Des123's Avatar
Des123
Des123 is offline
We bought it and the dude that owned it cut the radio wires and messed with the wiring everywhere because he thought he had a short. I've hooked up the radio and everything and it does the same thing. How do I bypass to make it stay running. The fors dealer told me it would be over $100 dollars and towing fee. So please help
Old 10-20-2016, 04:18 PM
vicv's Avatar
vicv
vicv is offline
does the key look like it is a copy from a store or does it look like it is from the dealer with a fat head? Not the dealer, the key. Maybe the dealer.
Seriously, You may not have the PATS key which is a security key that contains a chip to tell the car to start. Which is why I has a fat head.
Old 10-20-2016, 05:01 PM
Des123's Avatar
Des123
Des123 is offline
Lol dealers to have fat head a too.
I looked at the key and its not erignal key. They dealer said it would cost $100 or more for them to fix it and can't afford that
Old 10-20-2016, 05:10 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
My '98 had the chip in the key. It would turn over but not start without the chip.
Spend the $100. If you can't afford $100, you will soon be walking anyway as that's going to be your first couple tanks of gas.
Sorry to be so blunt, but it you want something semi-reliable, it needs to be fixed right. Otherwise why own the vehicle?
Old 10-20-2016, 08:07 PM
Des123's Avatar
Des123
Des123 is offline
Thanx but this key does have the chip. But I know theirs ways around it tho
Old 10-20-2016, 11:15 PM
shorod's Avatar
shorod
shorod is offline
A well equipped locksmith should have the capability to program the key if that is the issue, and they rate is likely less than the dealership.
These PATS systems on modern Fords are impressively well integrated and difficult to defeat. Even remote start systems don't defeat the system, they just act like another programmed key and require either two programmed keys, they learn an existing programmed key, or they require a professional-grade scan tool to program the remote start box to the PATS system. This system isn't like the old GM VATS system that could be bypassed with a resistor.
-Rod
Old 10-21-2016, 08:11 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
The only thing an ill-equipped DIYer can do is to replace the tranceiver module. That's the antenna ring that goes around the ignition key cylinder.
This era of the Explorer (98-01) has a stand-alone PATS module up under the dash, up in the vicinity above the gas pedal. Check and see if the PO's hack job harmed this module's wiring harness. Start there.
If the THEFT light is fast-flashing, the engine will crank but not fire on its own as the injectors have been disabled in the software. There is NO effective way to bypass this by an owner, you have to fix the problem so the system works.
Forscan with an extended license on a laptop will reprogram PATS. :thumb: Now within the easy reach of the DIYer.
Old 10-21-2016, 10:09 AM
exranger06's Avatar
exranger06
exranger06 is offline
If it was so easy to bypass or disable, it wouldn't be a very effective anti-theft feature, would it? It would defeat the purpose of it. I recently had a similar problem and I looked for ways to bypass the system to get it up and running cheaply. There's no way to do it. I had to tow it to the dealer and had them reprogram it. $246 out the door to reprogram, including $35 for an additional key (you need at least 2 keys to reprogram and I had only 1). That's not including the cost to tow (I towed it in myself).
Old 10-21-2016, 11:11 AM
projectSHO89
Simply reprogramming existing keys does not cure any known issues, according to Ford's own service documentation.
See attachment for 96-06 Fords.
File Type: pdf
Old 10-21-2016, 11:34 AM
exranger06's Avatar
exranger06
In my case, my problem was a failed ECM. I installed a junkyard ECM and had to get the ECM programmed to accept my existing key.
Old 10-21-2016, 12:20 PM
projectSHO89
Yeah, that's the "rest of the story" which does make sense.
fordfanatic05
Escape & Escape Hybrid
26
03-14-2011 03:04 PM
mrbigmark
1997-2006 Expedition & Navigator
01-04-2010 11:52 PM
Truckwrench
New Jersey Chapter
13
04-03-2009 03:52 PM
ppaquet
02-07-2004 03:39 AM
sell120
1997 - 2003 F150
11-17-2003 10:52 PM
Quick Reply: 98 ford explorer. Theft light flashing, turn over sometimes but shuts back off. How to bypass
