Rear Air Door Help
Old 10-19-2016, 09:44 PM
cwilkins002's Avatar
cwilkins002
cwilkins002 is offline
Rear Air Door Help
Hey guys - so the rear AC on my 2011 e350 quit working. It only blows hot air and nothing out of the top vents - only on the floor.
I'm thinking it's the rear air door. Does anyone have a part number that I can track down, and any type of instruction on how to replace that? I guess it could be the vacuum, but it seem that the door might be more prone to breaking.
I sure would appreciate any help.
Thanks!
Old 10-19-2016, 10:26 PM
GreeVan's Avatar
GreeVan
GreeVan is offline
Thanks!
Top vents only work with A/C and only blow cold air. Lower vents only work when the front air is blowing to the feet (and windshield?).
If yours do not work like this, I'll check the vacuum lines.
Old 10-20-2016, 06:19 AM
cwilkins002
That's right. The rear air blows cold only when the front is set to max, ac, or vent. It blows hot only when set to heat and defrost.
adjusting the thermostat dial does not change the temp of the air in the back.
Old 10-20-2016, 06:50 AM
GreeVan's Avatar
GreeVan
GreeVan is offline
Yep, that's the way is supposed to be. The Econoline world of luxury.
Old 10-20-2016, 07:39 AM
cwilkins002
So, do you have any pointers on how to fix this problem? I assume the rear air door has broken. I have not been able to find the part number to replace that door. I did find a vacuum motor control, but that did not contain the air door. Can anyone help me with that part? And also any pointers on getting that rear panel off and replaced.
Old 10-20-2016, 12:05 PM
GreeVan's Avatar
GreeVan
GreeVan is offline
I would have said that that is the way it is supposed to work, but comparing the owners manuals 2000 E150 , 2011 E350 It seems that after 2009 you can have hot or cold air comming form either one, floor or roof. In this case, I have no experience.
Old 10-20-2016, 10:15 PM
cwilkins002
that's not right. It only blows hot air out of the floor and only cold air out of the roof.
Help?
shakebaker69
1997 - 2003 F150
09-03-2013 06:13 PM
leogla
07-02-2010 10:35 PM
tk1251k
Aerostar
11-28-2007 05:21 AM
dsquarewd
09-09-2007 06:25 PM
mikeybr550
Aerostar
02-01-2007 09:59 AM
Quick Reply: Rear Air Door Help
