4.0 ranger crank no start
Old 10-18-2016, 07:18 PM
brandync93's Avatar
brandync93
brandync93 is offline
recently bought 94 ford ranger. when purchased was told fuel pump did not work. brought home found out ground wire in relay was no working. grounded it off got fuel pump to come on. still no crank. compression test was 90 because engine is cold. fuel pressure is 40 psi. I am getting spark. did test on injector with noid 'light. and no fire there at all. could use help. I do m asonary work not a machanic. these are the things I knew to test and the results I got also no check engine light at all. Evan tried to do self test with the eec. and still no check engine light.
Old 02-11-2017, 08:28 PM
Glenn Gay's Avatar
Glenn Gay
Glenn Gay is offline
I recently had $2,800 worth of timing chain replacement in my 2003 4.0 Ford Explorer Eddie Bauer edition with 200,380 miles now and the timing chain replacement was at 193,000 miles. It shut off going down the road and hasn't started yet. Turns over and wants to crank but coughs and burps and dies. I replaced the plugs and wires,fuel filter and checked the fuel pump. Also the inertia switch. So the repair shop has had it for 7-8 days now and no word yet. Calling Monday and will post updates.
Thumper47
1983 - 2012 Ranger & B-Series
06-15-2017 08:17 AM
slamnrangr58
09-13-2007 10:43 AM
diydan
09-06-2004 04:09 PM
deant
11-10-2003 04:43 PM
jjjerue
11-29-2000 12:09 PM
Quick Reply: 4.0 ranger crank no start
