Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
fuel tank sender for 67 F-600
Old 10-18-2016, 04:37 PM
gdp1701's Avatar
gdp1701
gdp1701 is offline
I have a 1967 F-600 with chassis mounted fuel tank. I am looking for a fuel tank sending unit. Does anyone know of a parts vendor that deals in trucks like this. I tried NAPA etc already. I have a Ford parts diagram for it, but it only shows reference numbers not Ford part numbers.
Thanks in advance for your help
Old 10-18-2016, 04:49 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
These tanks and the sending units are a real b!tch to look up!
Look on the sending unit for a stamped ID number, post what it is.
Be aware that the float is available by itself.
Pic: Does it look like this?
Old 10-18-2016, 04:55 PM
gdp1701's Avatar
gdp1701
gdp1701 is offline
This pic looks like it. I will go out there tomorrow and see if I can find a number on it.
Thanks
Old 10-18-2016, 05:35 PM
NumberDummy
Thanks
If the dash fuel gauge reads empty...the float is made of two pieces of brass soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
Take the sending unit out, remove the float and shake it to hear if gas is sloshing around inside.
Float is available from Ford, Carpenter has a one piece float that'll never leak for about 5 bucks.
Old 10-19-2016, 04:11 PM
gdp1701's Avatar
gdp1701
gdp1701 is offline
I did not find on number on the top side of the unit. Would it be on the inside? I have not taken it out yet.
Old 10-19-2016, 04:34 PM
NumberDummy
ID number stamped on the top of the sender.
Pic: Look at the applications for B8T-9275-A & D3TZ-9275-E (D3TZ-9275-E replaced B8T-9275-A).
Based on your 1967 F600, I would assume this is the correct sending unit.
D3TZ-9275-E =
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
NOS PARTS LTD in Waxahachie TX has 13 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 64 = 800-476-9653.
B8T-9275-A =
GREEN SALES CO. has 4.
CARPENTER NOS OBSOLETE PARTS has 7.
uh60
10-20-2013 10:13 AM
INTREPER
02-16-2013 09:17 AM
2005f-150
09-09-2010 10:54 PM
wdhille
18
06-22-2010 03:06 PM
Jimfrey
09-04-2006 02:37 PM
Quick Reply: fuel tank sender for 67 F-600
