1987 6.9 Leaking UNDER the IP
http://www.biotrieb.org/fileadmin/us...nual_99009.pdf
Complete factory instructions on disassembly, testing etc.
Just make sure to keep things clean on reassembly. Might be a good idea to use diesel or some light weight oil(engine oil might work) and assemble it under a "bath" of oil to keep dust out.
I've never done that, but I end up doing things wrong a lot...
Buy it from R&D IDI Performance - Home if you buy a new pump. Same price(approximately) and I trust him more than a random company.
I might be in luck. It looks like the leak is coming from either the injector, fuel line or the piece in between.
I doubt it's the fuel line. I've never had a bad fuel line NOT gush out diesel. It's definitely leaking from there. Do injectors leak? Or do they just go bad and not work and get glossed?
