Just finished solving my oil leak (woohoo!) and radiator hose leak. Then I noticed diesel.
I dont think its the fuel lines because usually they gush out diesel. I cant see a single drip while the engine is on. But I wiped it clean last night. Drove about 25miles today, and its definitely got diesel there. It seems like its past the injector lines, closer to the bottom of the IP. Anyone know what this could be?
Im wondering if its actually coming from the other side (closer to the turbo) and washing up to the front by the injector pump. I cant see any leaks/drips.
Cut out some Polyethylene foam to divide the IP side from the other side. Gonna put some paper on both sides and see which gets hit with diesel. I hope the foam doesn't melt.
The fuel screw cover is that triangular thing. it's help on with some 1/4" hex screws. Tiny little *******s. It could be leaking from there. But that's just a guess.
There is a weep hole near the front. It means that the internal "umbrella" seal is leaking. You'll have to buy a seal kit and totally disassemble the IP to replace.
