rough idle
Old 10-25-2016, 10:32 AM
eaglefire21's Avatar
eaglefire21
eaglefire21 is offline
I will check uvch , the part that is confusing is the idle clears up when throttle up it idles normal and throws no codes, as for the dealer if I want to see clowns I go to a circus, better act
Old 10-31-2016, 07:39 AM
eaglefire21
replaced uvch gasket and plug that was melted still have same issue, three of injectors on drivers side that have little or no oil coming out of oil deflector, I will guess with high mileage time to get injectors done
Old 10-31-2016, 07:41 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
http://dieselpro.ca/Poppet%20Valve.pdf
Check armature clearance to be sure
Old 10-31-2016, 03:01 PM
eaglefire21
learned something new there, have a pressure gauge to check hpop pressure to eliminate that what is best port to test from
Old 11-05-2016, 10:05 AM
eaglefire21
finally got hpop pressure test done 800psi at idle and 1000psi at 1500rpm, what is the specs for the hpop
Old 11-11-2016, 05:24 PM
eaglefire21
have injectors out to rosewood's, will be upgrading to stage one's
Old 11-12-2016, 06:54 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
You're gonna like them!
Old 11-12-2016, 12:08 PM
eaglefire21
I be happy if when the trucks running sucks when you can't jump in and go, will need to do hpop next to keep up with them it's on the weak side
Old 11-28-2016, 10:14 AM
eaglefire21
injectors in more power and better idle, first road trip showing better fuel mileage and smother ride. adrenaline hpop shipped today
Old 12-05-2016, 11:27 AM
eaglefire21
Installed adrenaline pump drives like a real truck now
Old 12-05-2016, 12:36 PM
Jarrett Campbell
Glad to hear you're happy with the upgrades!
john stelly
16
05-06-2018 04:19 PM
colbster
08-19-2011 06:36 PM
topdawgtrkr
12-16-2010 07:36 AM
turtlehead
12-12-2010 09:06 PM
Quick Reply: rough idle
