Different year / generic tail pipe
I think I've sorted my y-pipe needs and am now looking for the other end of the exhaust for a 3" SS mandrel bend mail order system for my new 351W install into a '77 F100 2WD.
Any reason something like the Dynomax 54745 2011-14 tailpipe (link takes you to Summit) or a generic truck tailpipe (link take you to Mandrel Bend Solutions) won't work?
I know if it has pre-installed hangers they will almost certainly not work, but I mean just from a viewpoint of it fitting in place reasonably well?
Once I've got the front and back pieces sorted I'll try out a muffler/resonator combo and join them up with some 3" SS tube with a mail order custom offset piece or two if necessary.
Thanks! Engine will be coming home from the speed shop soon.
1996 351W roller block build
I've used the magnaflow 15003 on several exhausts with great success. It's a 3" mandrel bent stainless pipe, universal for pickups. Expect to shorten it at the least if not cut/chop/rotate and re-weld it depending on how picky u are about fit.
Stainless is a bitch to cut, you'll need a chop saw, cutoff wheel or special sawzall blade.
Thanks much guys. I know I can count on getting good advice here. I ordered the Dynomax tail pipe today and I'll feed back on how it looks. I have a guy who can do any welding required so I'm heading toward getting the swap started. Next question, for another thread, is whether to swap a 4R70W in for the C-4 while I have the engine out.
Thanks,
Travis
Thanks,
Travis
Metalhead47
05-18-2014 12:16 AM
hairyboxnoogle
02-09-2013 06:30 PM
MEPHISTO_XES
07-23-2001 05:16 AM
